230 Deisel Leak
Anonymous-0
I have a 230 MF and it has a deisel leak that I believe is coming from the injector line connector that is the closest to the outside of the pump when you are setting down looking at it. I read on an earlier post of a banjo copper or brass washer under there. Where can I get one to replace it or what else will work? Thanks.
