Hi,
I could use some advice on a '78 30B with Perkins AD3-152. I was using it over the winter cutting some firewood. It was idling and all of a sudden it started making an unusual sound out the exhaust. It lost nearly 60% of it's power too almost like it's running on one or two cylinders. Upon further review, it seems to be making a huffing sound out the intake? No unusual white smoke out the exhaust or bubbles in the radiator which would say it's a head gasket for sure. I pulled the fuel tank and valve cover. The valves could use an adjustment but nothing extreme and all the valves are opening and closing fine. If one of the valves was hanging open the tappet clearance would be excessive and this is not the case. It use to start very easy. Another symptom is now it takes a lot of effort to get it running and when it does, there is hardly any power. One other thing I noticed is the valve cover and rocker valley of the head are painted with Glyptal paint. Did Perkins do this in the factory or is this a sign the engine been rebuilt at some point?
While I think I know where this is going and before I pull the head and all the fun that can lead to, I thought I'd get some input from the group here. If there is an easy way to get the head off due to rust and carbon build up, please let me know.
Thanks for any and all advice in advance.
Best regards, C3
Best regards, C3
