165 Massey ferguson.
KYCASE1
I have a 165 that will not go into high on the multi power. The tractor pulls good in low but when you shift into high it stays in low. the linkage looks good and does not look like it has slipped or broken. Is there a port that in can check the pressure to shift control valve. Any help would be greatly appreciated. Dennis
Dennis, Try this. With the dash lever fully up,
follow the linkage down to the pin that goes into
the trans.Loosen the clamp around the pin-make
sure it is loose, then lightly tap the pin down
while holding up on the clamp-then retighten.
usually works. Chuck
After adjusting and working with the linkage and having no luck, I have split the tractor at the engine. It looks like the linkage is trying to move the spool, but it looks like the spool is stuck and will not move. I have not removed the clutch cross shaft yet so I can get to the spool but was wondering how stiff the spool should be. Is this a common problem and is there other stuff I should check wile I am in there. Thanks for the help Dennis
