Glenn Rollins
New User
Hit a soft spot while disking with my 135 and sunk to the frame. With 3 pt lift high as it would go I got the disk off so I could pull the 135 out. Picked up the plow with the 4105 JD I bought myself as a retirement present!! Today I got on the 135 cranked it up and the lift went straight up. Controls do nothing. It will leak down very slowly with weight when not running, but if you crank it goes straight up even with both controls down.
Has anyone has this happen? Can you tell me where to start? I have had the tractor 15 years with no problems and lift has been perfect! My wife says it hates sharing the barn with the JD!!
Please help. Thanks
Please help. Thanks
