morgan in ar
So, I have this mf 50 with a multi power that slips in high. I would like to fix it the right way, but I can't find much information on how to do that. First, I bought an I@t manual for it. This manual doesn't even mention multi power. Then, I bought a Massey service manual. This manual only gives two paragraphs about operation of the system, and how to disassemble the hydraulic clutch. It doesn't talk about the pump or valve, or any trouble shooting at all. What should I do? If I go ahead and split the tractor, will it make more sense? Do you just have to shotgun it? Or keep splitting it and replacing parts until you get it right? Is there a better resource out there?
Another thing about Massey. When you look at that tractor, you think "what a simple tractor." What you might not realize, is that all of the linkages, hoses, pumps, and other complicated stuff, it's all on the inside!
