Rebuilt the control valve, the oil seal was leaking bad. I can't seem to get it to work now. I've adjusted according to the service manual, it seems that the spool should pull out when turning right. My problem may be that when I removed the main arm from the pedestal shaft I didn't mark the location, I see the master spline on the shaft but nothing to align on the main arm. My setup is with the swivel link that has a bend in it, my last attempt I got the spool to pull out of the valve on a right turn and it seemed to be working but nothing trying to turn back straight. As you would imagine there is wear in the anchor pin and or cylinder rod so I think that could alter my adjustments slightly, any advice??
