Hay hay hay
MF65 Gas
Well the mystery of disappearing gas is solved.
Sometimes (but not always) when the shut off valve is closed, it leaks...draining gas onto the gravel floor of the shed..and disappears. Leak is up high, between the valve and tank.
I Plan to install a new shut off valve, with 2 pipes, regular and emergency. Who sells these valves and is there a seal kit for where it goes into the tank? Is there a secret about breaking the assy free without damaging the tank? Thanks
