Hi,
I recently had a repair / adjustment done to my dual stage PTO / Clutch on my MF 165 (hope that the right term)
Everything worked fine for about 20 hours, I was told the bolts was loose.
I was just outside trying to adjust the 3 adjusters under the inspection plate, but it seems no matter how much I loosen the bolt shown on the left (towards the rear of the tractor) it just stays in place. There seems there is no way to insert a feeler gauge from what I can tell.
Never done this before, searched on the internet for hours, but alas I can't seem to get the left bolt away from the little "metal block" for lack of a better term..
I know this is noobish question, but I really have tried this repair and I simply must be missing something.
If someone could help me out, that would be great, thing hardly cuts in 1 gear low now and I got a field to cut.
Not sure if I need to jam the feeler gauge in there or if the bolt head should move away from the block of metal (little 1" or so square piece).
Anyhow lemme know what you think and thanks.
MajSlayer
MajSlayer
