Third remote on 1155
You can add a non factory closed center valve pretty easily.
One the right side of the lift cover you can T into the supply line.
Put the return back to the trans case. I did one on an 1105
years ago, put an electric valve on, mounted the switch on one
of the remote levers.
did you ever get anywhere with your 3rd remote kit? I have a factory 3rd kit minus the hoses and outlet ends. I do have some other MF coupler ends that would work though. Let me know if I can help.
Thanks for the reply, we ended up getting a two spool multiplier from Shoup, Fasse I think is the brand. It plugs directly into the spools on the back of tractor and is selected by solenoid switch in cab. Looks easy , but haven't hooked it up yet.
(quoted from post at 03:12:46 04/20/14) did you ever get anywhere with your 3rd remote kit? I have a factory 3rd kit minus the hoses and outlet ends. I do have some other MF coupler ends that would work though. Let me know if I can help.
MFbucker,
I'd be interested in that factory MF third remote valve kit! Does it have the factory three spool valve stack that goes inside side counsole w levers/knobs and three slot cover plate with decal? The missing coupler ends and hoses are no big deal.....new hoses are available from Agco and I changed my other ends to a quick disconnect coupler anyway. If it's still available let me know by email @ [email protected] Thanks
