Massey Ferguson 30 Industrial wheels
Roy Monzo
New User
I"m trying to find out what others may have done to
put wider tires on the front of a MF30 Industrial.
The 6.50 tires are too narrow for the moist ground I
encounter and would like a wider foot print of 10-
11" width. The tractor is a 1975 year with a very
heavy industrial loader.
Any help will be appreciated.
Shouldn't be hard to find wheels. Just measure the bolt pattern. I worked at a golf course that had an MF30 loader with 19.5L x 24 rears and 11.0 x 15 fronts.
Measure the bolt pattern and check with tractor wreckers or dealers. The wheels probably aren't anything special and might even be a common implement wheel. The wheels would have come new from the factory when they bought the tractor.
Thanks once more. I've begun working with tractor junkers,and others who might have just the right item in the back room or field.
Also, I've measured accurately all needed measurements so I'm hopeful someone will have a match with or without tires
Have a Happy Easter
