So the title isn't completely accurate. My 1030 won't start using the starter. I have been able to start it by pulling it behind a buddy's truck and jumping it.
I started it once a week all winter long and never had any issue even when it was 20 degrees outside. About a month ago I started it up no problem as usual but didn't let it warm up long enough before letting off the throttle and it died. After that it hasn't started since.
It turns over and when you give it some throttle even smokes a little but won't start. It's a brand new battery and has no problem turning it over. After jumping, it runs very rough and has no power. Anything below 1/3 throttle and it will die. RPM accelerates very slowly and will not reach normal max RPM. When I let off the throttle it billows black smoke.
I emptied the tank and put new diesel in it. I've bled the entire fuel system from tank to injectors. I'm getting good flow all the way to the bleed screw on the side of the injector pump. I'm getting fuel to the injectors but I feel like the volume/pressure coming from the pump might be low. I don’t have enough experience with diesels to know by looking. I even tried running a hose directly from the tank to the injector pump to bypass the fuel filter in case it was clogged or letting air into the system somehow. I used a brand new inline fuel filter just to be safe.
I took the injectors out, disassembled them and made sure everything was clean. They looked fine to me but I did notice that the injectors don't match. Parts are very difficult to find for this tractor so I assume somebody worked on it in the past and had to use a substitute injector. I'm not a diesel expert by any means so I don't know how critical it is that the injectors be the same. I'm sure they need to perform the same but is it possible to have different part numbers?
Can anyone tell me what the correct injector is for a 1986 MF 1030 with an 87 cubic inch, 3 cylinder, Toyosha?
Sorry for the long post but I wanted to be thorough.
I really appreciate any advice you guys can offer. I'm running out of ideas.
