MF 274 Clicking front end rear left tire lockup
Case450
I got my old "84 274 into the shop last week to do some much needed repairs. The front end makes a clicking noise when travelling in reverse only and every once in a while the rear left tire locks up when travelling forward. If you reverse about an inch or so and than continue forward it seems to unlock the wheel, at least until that wheel is loaded (has some weight on it). Typically during flat ground travel it rotates easily.
I removed the left rear wheel and hub and cannot see anything wrong/broken/dirty/shavings in the hub so I am going to put that back together soon.
Any ideas where I should start disassembly/looking for? Any help would be much appreciated. Thank you for any help you may have!
Well I removed the front wheel hubs and found a chewed up u joint on the front right axle hub. Now to find parts.................
Haven't tore into the brakes yet....that part seems more daunting lol
