Snow Chains for MF 30E
KEN D
New User
I don't seem to have the clearance between the fenders and other supports such as the loader brackets and the tires for chains. Has anyone had this problem and is there a solution? KEN D
Are the wheels dished in or out now?
I am thinking dished in like every "yellow" I've seen.
Can you swap the RH wheel for the LH to dish them out?
You likely can gain at least a couple inches on each side by mounting the wheels dished out.
(quoted from post at 20:26:57 04/13/14)
Thanks 495, I am going to check that out. Only problem is, the wheels are really heavy, they have fluid plus wheel weights; I guess I need to bulk up before next winter. Thanks again, Ken
