TractorLinks.com
Show Parts for Model:
Re: mf 175 pto
samn40
04-13-2014 01:26:19
Sounds like you need to set your clutch ? setting is done through the inspection plate underneath. (3 different setting points!) About the thickness of a standard hand held hacksaw blade is good. Which lever are you using on the 3 point? The outer lever is draft setting, the inner one position control. It needs to be set in the raised position to work the draft lever, likewise the draft lever needs to be fully raised for the position lever to work correctly............Sam
