Fuel Tank Valve
rusty6
I think I need a new fuel tank shut off valve for my Massey Super 90 tractor. I'm in the process of replacing the head gasket and found the threads were bad on the brass outlet valve at the tank shutoff. Then I damaged it further!
Checked with the agco dealer and that part is no longer available. 198142M91. I guess I can try and rig up some type of makeshift repair unless anybody has any ideas where a valve might be available?
If you can't get a shut off/ sediment bowl to bolt up, find a plumber, they are all common threads, all you need is a gate valve of some sort right? A couple hours in true value or home depot and you'll have it figured out! Did you ask an old timer at NAPA?
