TractorLinks.com
Show Parts for Model:
Re: multipower troubleshooting question
Dieseltech
04-11-2014 04:26:03
Problem on this model is no place to check the pump pressure and flow without removing the lift cover. If the pump does check out OK then I would suspect burned MP clutch pack discs. Even if the pump is good, running low on oil, or worn input shaft cast seal rings will leak off the clutch pack apply oil and damage the discs.
morgan in ar
04-11-2014 04:53:16
 Re: multipower troubleshooting question in reply to Dieseltech, 04-11-2014 04:26:03
Thanks, my I@T manual doesn't have any multipower information. Would a manual for a 150 be similar?
Dieseltech
04-11-2014 07:09:54
 Re: multipower troubleshooting question in reply to morgan in ar, 04-11-2014 04:53:16
Will help you with how the system works, late tractors had gage test ports, early 150 is like the 50, no test ports at all.
