Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 162 163 continental motors
bp4455
04-10-2014 12:28:40
the industrial motors usually had more compression and higher power ratings. should bolt in with your mounts
Massey farmer
04-10-2014 12:43:49
 Re: 162 163 continental motors in reply to bp4455, 04-10-2014 12:28:40
Thanks, I read somewhere about holes in the end of the crank where pilot bearings are might be different? Would you know about that?
MH55
04-11-2014 07:39:52
 Re: 162 163 continental motors in reply to Massey farmer, 04-10-2014 12:43:49
The 163 crank will need to be modified for clutch pilot. Also the industrial engines can have different arrangements for side covers, oil fills and such. It can be made to fit, but may not be a direct bolt in affair. Where are you located in Avon, I may be interested in old 162 if it's not to far gone, and I'm just down the road in Liecester... Email is open, send me a message.
Mike in Mn.
04-10-2014 17:54:46
The one I did years ago, the crank did not have a hole drilled for a pilot bushing, I made up a bushing to fit inside the flywheel like the 44 used and cut the nose off the clutch shaft.
Copyright © 1997-2015 Yesterday's Tractor Co.
