I'm trying to figure out a problem with my Instant Reverse trans w/Torque Converter and was wondering if someone with knowledge could answer a question:
Is the sump plate supposed to have two openings or flow channels between the two reseviors to allow trans oil to pass through?
Someone ground two channels in my sump plate, probably for flow purposes, then they were welded back closed. I can tell it wasn't factory, because the grinder hit another spot just a little, so I know it was custom done. Then, someone welded them back up. I'm just wondering because I am trying to figure out a problem with instant reverse. After it warms to working temperature, it takes a long time to go either forward or reverse. Once in forward in reverse it has lots of power and does not slip. When the oil is cold, it goes into forward or reverse immediately and has lots of power. I'm wondering if it is heat related, or something with the oil distribution manifold, maybe with the control valve or two regulator valves, but I don't know at this point. I did replace the clutches in the clutch plates already, so those are good. This problem existed the same before and after I replaced the clutches.
If someone could answer my one question above that would be great...thanks.
