11.2 x 34 inch title
CharlesTx
Location
Central Texas
One of my mh-22 rear tires has started to separate from the casing on the sidewall. The tire is still holding air but will need to be replaced or repaired. I"m at a loss at how to repair, has anyone came up with repair method? I found a new tire made by Titan listed at $625. This is not a show tractor so the price would be half what the tractor is worth. Would strongly consider used tire.
check out tire reliners from gemplers they are reusable for the next tire. depends how bad your tire is and how hard you use it .
Titan tire was the last manufacturer making 11.2x34 tires and their warehouse is out of stock. They have no plans to make more, at least not in the near future. $625.00 is about the going rate. If you find one you better buy.
