TractorLinks.com
Show Parts for Model:
Re: 135 Carb problems
FBH44
03-24-2014 02:05:40
Well, one time I had a Farmall H that did that. Finally found that [ hate to addmit this ] I ovedid it to the point I used pipe dope on the sediment bowl threads going up into the gas tank. I had used somuch, I had it ooze out into the inlet of the bowl; had barely enough flow area. It would flow a little tiny bit, but blocked off flow for wide-open. Finally found it, removed the glob, all was well.
ditch
03-27-2014 08:19:02
 Re: 135 Carb problems in reply to FBH44, 03-24-2014 02:05:40
Little update on the carb issue. I took the little spring off of the needle that connects to the float,turned the gas valve on and the gas filled the glass bowl up quickly. thought i was onto something which i think i am. but the tractor still run out of gas within 2 or 3 mins of running.
ditch
03-24-2014 05:39:54
all i used was a little bit of thread seal tape. but i am going to take it off again today and see whats going on. i will let you no my findings ,Thanks for all yalls help
