Anonymous-0
Just rebuilt the motor actually whole tractor. Tractor did run fine before rebuild lessthe knocking noise (reason for rebuid). Rebuilt the carb also. Tractor will run 3 or 4 mins then stalls i turn the swith off wait about a min then starts right back up. I have taken the carb off and apart and checked for trash several times and nothing. I have put the carb on manifold without fuel bowl turn fuel on and it dont seem to have enough fuel coming thru neddle and seat. i have taken fuel bowl out of tank checked for any blockage nothing there either. i have checked fuel line itself no blockage. Even removed gas cap while checking thought maybe not venting. One thing i did notice when i put carb back on tractor with fuel bowl empty i turn gas valve on and gas will slowly fill up the glass bowl and i mean slowly. but if i crack the fuel line at carb it fill quickly ,seems almost like a vapor lock ..could this be possible. sorry for the long post but i am stumped..and i know someone here has a answer ,thanks in advance
