Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 135 Carb problems
FBH44
03-23-2014 18:17:08
Some carbs have a small hidden inlet screen, just inside the inlet pipe connection, could it be it never got cleaned out?
ditch
03-23-2014 18:26:21
 Re: 135 Carb problems in reply to FBH44, 03-23-2014 18:17:08
I have cleaned the carb to the point where i put a small wire thru every passage that i saw . One thing i did do is i removed the brass 90 with the screen that was attached to it and replace it with a regular brass 90 with a compression fitting. the reason i did this is because the guy i bought the tractor from just had a lot of tape on the fitting that didnt actually fit the brass 90 with the screen
Phil Tibbetts
03-23-2014 20:06:03
 Re: 135 Carb problems in reply to ditch, 03-23-2014 18:26:21
I think your problem may be a piece of the tape is blocking your flow somewhere. That is one problem with Teflon tape. Whenever I use it I always stay 1 thread back from the end. Whenever you replace a fitting that had the tape there is almost always some trace of the tape left in the female thread. Hope this helps. I
ditch
03-23-2014 20:19:04
 Re: 135 Carb problems in reply to Phil Tibbetts, 03-23-2014 20:06:03
Thanks Phil, I cleaned the carb out with small wire ,used brake cleaner, and compressed air. i have looked for any trash and cant find anything.
Copyright © 1997-2015 Yesterday's Tractor Co.
