Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Bore a 226 continental
Curt Courtney
03-23-2014 12:55:02
can you go to a 3.50 bore on a 226 continental and if so what would be good pistons and valves to use?
Mike in Mn.
03-24-2014 18:49:46
 Re: Bore a 226 continental in reply to Curt Courtney, 03-23-2014 12:55:02
A short story, about 25 years ago I resurrected a worn out 333 with a shot engine, made up my mind to put a flat head continental in it, found a 244 in an Oliver combine. There used to be a Continental Dealer in the Twin Cities, talked to the machinist there to see what I could do for max power and long life, I was going to use this tractor on the farm. He said stay away from the 244 cause they all cracked by the exhaust valves, said find a good 226 and he would bore it 40 over for me and it would live a good long life, put in hard seats and stellite valves and he said it would run 10,000 hours on propane. I took his advice and I still use that tractor today and have never touched the engine, many, many hours of use. I will also add, not a lot of power by todays standards and it will not lug down like a 4 cylinder will.
03-23-2014 15:21:31
I would say no, I have a bad 226 block that I broke out the cylinder on purpose. The wall thickness on that one was about .110 inch thick. A 244 block is 3 7/16 like the 162. .060 over would be 3.4975, closer to what you want. Only problem is finding a 244 block, not as common as the 226.
