MH44 generator
I just bought a 1949 44 GR and it had no battery in it. I need to find out if genny in it is 6volt. There are no tags or ID numbers on it. I attached pic of what my genny looks like. If you have a 6 volt MH44 can you see if my genny is like yours. Also, were they positive or negative ground? Thanks
you were right. The generator, and voltage regulator were 12 volt, as was the starter. I took it all to a auto electric company in Spokane, and had them see what I had. They went thru everything and it is ready to go, even got ballast resistor to protect points in distributor. I bought new wire harness from Brillmans as mine was shot. Now putting it back together
