Size of front weight bracket
Anonymous-0
I am in need of a front weight frame for a MF65, (or a MF175 weight frame), could someone please post dimensions of steel thickness and height of frame at front ?
The bracket is six inches in height, 3/8 of an inch thick.
Thanks for the replies guys!
are both answers correct ?
i can image this may happen with product revisons over time, an oem or aftermarket might have been thicker for larger weights, or an orignal designed for lighter suitcase weights might be thinner.
As i am having to counterbalance an 800+kg weight on 3pl I'll prob err on the side of caution and go with the half inch unless the engineer says otherwise.
thanks again!
Mine is 3/8s for sure. it's from a 1959 65. I'm not sure if it,s heavier in my 180 but the same weights work on both tractors.
