Anonymous-0
I have a MF 235. had some work done on it. new distributor, some carb work, and some other things. its had this problem every since. (it dies). it starts O.K., runs O.K., might run 5 minutes or maybe an hour but it'll die on ya almost as if you shut the key off. seems to have spark and gas to the carb. it won't start right back up. choking does not help to keep it from dieing or the restart. leave it sit for awhile (maybe half an hour) and it will start back up but run rough for just a bit and it'll smooth out and run O.K. for awhile but will eventually die on ya again at some point. I've tried a different coil, condenser, and still the problem. weather makes no difference. I'm just stumped. Its almost like it vapor locks, but what would cause it do that when it does it in different kinds of weather. I'm just baffaled. Any idea's? HELP!
