I have a 1962 MF 35 with the Perkins diesel. I was having cranking issues turning over too slow. Battery checked good, troubleshot it to the starter. Pulled the starter and it looked like it was bathed in motor oil. Is this an indication of a blown rear engine seal? It was low on motor oil. Also there is a plug directly under the rearmost part of the engine, takes a 9/16 wrench to turn it. Does this plug drain the crank case or just the flywheel area. I drained about a quart of motor oil from it before plugging it back up so I wouldn't drain all my oil out. This is not the same plug I pull when changing the motor oil. Thanks for any help.
