tach drive 230 massey furguson diesel
Is it just the tach cable? Yes you can remove it easy enough. If it is the internal drive you should be able to remove the plate from the back of the camshaft and remove the drive with something like a pair of vise grips. It is splined into the end of the shaft and is a tap in fit.
Sam
(quoted from post at 01:26:19 01/19/14) Is it just the tach cable? Yes you can remove it easy enough. If it is the internal drive you should be able to remove the plate from the back of the camshaft and remove the drive with something like a pair of vise grips. It is splined into the end of the shaft and is a tap in fit.
Sam
Gary did you ever get around to checking out what Sam had advised to connect the tach cable?
Tim
