Massey 65 Multi-Power problem
cropspray 1
New User
I have a MF 65 that has Multi-Power. It leaks Hyd. oil out of the clutch inspection plate area when it is being used. The High and low work great and it leaks worse in low. What would I expect to have to repair once I split the tractor? Has anyone been in these with this problem?
There is a valve in there for the high and low. There is also a hydraulic hose that feeds it. I would suspect one or the other is leaking. While you had it split I would check out the clutches, throwout bearing, pilot bearing, and maybe even the rear engine seal. You might want to checkout your ring gear as well. I just did the clutch on mine this winter. I wish I'd taken some pictures.
This is a pic of my mf165 clutch bell house. The control valve for multi-power sits on top of the input shaft retainer housing.
I can't find how to post a pic to this site, was an advance reply section that had a place to post a pic. Tried to paste a pic, that didn't work.
multipower valve mf165
