TractorLinks.com
Show Parts for Model:
Re: MF-3090. Clutch bleeds off and will not go to high range
oj
01-28-2014 05:27:36
I think the hi low range selection is done by an electronic switch.. They're not unknown for playing up, iirc it's on the right hand side of the transmission, by the main gear selector, check the wiring on that...
As for the clutch, the reservoir is filled from the tranny housing by the pump, so should always be full, Like Sam says, probably the slave cylinder, if you can get to the hydraulic line, maybe take it off and see if the master cylinder is sending oil under pressure to the slave... I know to bleed the brakes that the return line from the reservoirs back to the tranny needs to be clamped off (vice grips)
Gordo - Texas
02-28-2014 10:52:12
 Re: MF-3090. Clutch bleeds off and will not go to high range in reply to oj, 01-28-2014 05:27:36
This is Gordo. I want to thank both of you gentlemen for your response and ideas to remedy my dolema. I did not write down my access information so this is the only was to thank you men for your advise. I will try the troubleshooting methods you suggested.
Thanks
Gordo
