Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1100 massy
robert major
01-27-2014 21:56:09
Might be wrong here but I thought if you loose all hyds and pto it could be flywheel coupling to pump drive/pto shaft. If rear trans to diff housing pto coupling goes you only loose pto drive to back and everything else works still with the charge pump feeds. Think that's how the 1135 works and aren't they basically the same pile with a few modifications and a different badge!
Regards Robert
01-28-2014 04:47:22
 Re: 1100 massy in reply to robert major, 01-27-2014 21:56:09
The charge pump is driven by PTO clutch drum which is driven by a shorter shaft. The front of this shaft has a coupler to connect with the longer front shaft. When either the coupler or flywheel coupler fail the PTO drum no longer drives the charge pump, and it's still a guess as to which on is bad.
