TractorLinks.com
Show Parts for Model:
Re: MF-3090. Clutch bleeds off and will not go to high range
samn40
01-26-2014 14:26:07
I have not had any experience with the 3000 series tractors but it does sound as if your clutch cylinder seals are gone. More than likely the master cylinder. This will leave you with no pedal even if the resevoir is full. The slave cylinder usually leaks externally. On these tractors there was a mod done to the high low called an anticrash device. It was to stop operators crunching the range gears causing failure to engage. Once the mod was done these tractors were very good machines, but it did damage their reputation early on....... Sam
