engine timing MF65
my tractor is not running well so decided it"s time for a tuneup. the one thing i"m not sure of is engine/ignition timing because my manual says nothing about it, other than give the specs (it does say you should take it to the dealer for timing). i know how to time a car. but i can"t even find the flywheel with the timing mark on the tractor. (i spent some time searching the forum, but didn"t find anything).any help?
The inspection hole for timing is on the same side of the engine as the distributer. It is a fairly small hole - approx. an inch and a quarter in diameter. It had a spring loaded plug in it from the factory which may be lost by now.
I re-read your post and I am still not sure if you have these specs or not so I'll include them anyway.
