I'm rebuilding the power steering cylinder on my 65.... It's the type that is held together by long bolts. It came apart just like the shop manual says with the exception of the control valve. it tells me to remove the allen head screws from the 2 holes beside where the fluid lines are. Here's where the problem is... there are no allen heads in there. There's something in there but it's smooth
it's not filled with grease or dirt, it's metal. Looks almost like looking at the top of a ball bearing... Once again can someone help a rookie out??
