Z120 engine
Ed Paxton
New User
I was wondering if anyone knew what a rebuilt Z120 engine would be worth. Trying to find one on the net no luck. I am in the process of rebuilding one but not sure if it is worth the work.
Thanks Ed.
Ed in my opinion a new motor is always worth the work! There not cheap i have seen them maybe 1500 to $2000 just take your time and spend about $500.
Thanks for the reply. I was thinking it should be worth at least 1500. and yes I think 500 to 600 will do the job.
hi
someone to come to my aid,I"ve bought an old engine mf 65 mk 1 with a wedge between the sum and the bell housing.I"ve a problem with fixing the injector bump.the engine came minus this,thus i wanted to put in another injector which belong to a mf 35x but a link is missing which is suppose to connect the bump and the idler gear/the gear link to the injector pumb.a coupling of some sort,with some splines on both ends, i miss the technical word for it.It is difficult to access a mannual in this part of the world; kenya.somebody to advice me on what to do,where i can this component.
