TractorLinks.com
Show Parts for Model:
Re: lubrication system on MF 35
maxwell99
01-21-2014 05:16:36
Brain,
my old 1957 TO-35 has a washer and spring inside the oil filter canister,
this washer and spring go on the bolt first then the filter, this spring pushes down on the filter and holds it against the motor block.
if you do not have the spring and washer inside the filter, the oil will just flow around the filter, even if you have a filter in the canister, you have no filtering action.
might check your system out, if you have a later model tractor, your system may not require the spring and washer.
