TractorLinks.com
Show Parts for Model:
hydraulics to the MF-65
Rkh
01-19-2014 07:52:19
I put on a front bucket couple years ago, but the only way we thought you could hook hydraulics was with a pump hook up to rear PTO. is it possible with the continental gas wide front end to hook hydraulics to the front of engine?
Patiolant
01-21-2014 18:27:08
 Re: hydraulics to the MF-65 in reply to Rkh, 01-19-2014 07:52:19
I put a front pump on mine (1961) with no issues. Used a factory adapter plate that bolts to the crank pulley and accepts a threaded shaft running to your pump. The adapter plate has a rubber core that negates the need for a flex coupling that may give clearance issues. I set it up as an independent reservoir system and it works great.
rkh
01-22-2014 16:18:31
 Re: hydraulics to the MF-65 in reply to Patiolant, 01-21-2014 18:27:08
Do you have pictures
Bob N.Y.
01-19-2014 17:13:51
Eric is correct about the clearance issue on the earlier 65. It was corrected on later models by using shorter arms on top of the spindles.
rkh
01-19-2014 18:30:53
 Re: hydraulics to the MF-65 in reply to Bob N.Y., 01-19-2014 17:13:51
Can you put on shorter tie rods on the older mf-65?
Bob N.Y.
01-21-2014 16:47:57
 Re: hydraulics to the MF-65 in reply to rkh, 01-19-2014 18:30:53
Yes
rkh
01-22-2014 16:22:46
 Re: hydraulics to the MF-65 in reply to Bob N.Y., 01-21-2014 16:47:57
Put power steering on & had to change steering arm that goes from pedistal to tie rods. Can I still change to shorter arms?
Bob N.Y.
01-25-2014 04:40:52
 Re: hydraulics to the MF-65 in reply to rkh, 01-22-2014 16:22:46
Yes you can. We got into this problem many years ago when my father bought a Superior loader with a front pump to put on our 1960 MF 65 high arch.
Bob N.Y.
01-21-2014 16:47:04
Yes
Eric in IL
01-19-2014 09:00:12
A front pump is possible. I think some of the 65's had a clearance issue though, between the drive shaft to the pump and the lower steering arm.
Time to check the bushings on the front end pivot point if you are using a front loader. Those bushings are very thin walled.
