Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: mf-65 cause of engine revving up down
Rkh
01-19-2014 07:48:25
when your going straight, rpm"s are steady. only when you are turning steering wheel(even sitting still) the engine goes up & down. you can see the out of round(est. 1" play)in the steering wheel when turning steering wheel while sitting idling. not sure about bolts-are talking the base of the steering unit?
Rkh
01-19-2014 10:35:25
 Re: mf-65 cause of engine revving up down in reply to Rkh, 01-19-2014 07:48:25
just pulled steering wheel off steering rod-goveror is held on to a pipe that surrounds the shaft.that pipe is loose around the shaft. that pipe happens to be cracked(I dont think that has any bearing on why rpm's go up & down, but the shaft is bent bad. will the steering shaft come out if you take the 4 bolts on the base of unit?
rkh
01-19-2014 11:30:56
 Re: mf-65 cause of engine revving up down in reply to Rkh, 01-19-2014 10:35:25
Was wondering if you couldnt somehow hold the throttle rod to the metal underneath instead of steering shaft? The bent steering rod wouldnt have tobe fixed, if theres a way to hold throttle rod in place.
Copyright © 1997-2015 Yesterday's Tractor Co.
