Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
1155 engine repair
farmer-chad
01-18-2014 10:15:41
74.122.0.210
Hello, our 1155 with about 3800 something hrs either blew an injector or dropped a valve, not sure yet, it still runs so piston didn't come apart but must have a hole or crack because it blew a couple of quarts of oil limping it about 3 miles to get home.
Anyway my question is can I get by on the cheap by putting a sleeve piston kit in the one bad hole, we barely put 50hrs a year as a back up tractor. The engine was fairly tight and used little oil. Would doing this be OK or a big no no?
Thanks
[Reply]   [No Email]
Ctuna
01-22-2014 06:55:21
71.40.111.33
 Re: 1155 engine repair in reply to farmer-chad, 01-18-2014 10:15:41
Maybe ether caused the rings to break. Richard has good recommendations.
[Reply]  [No Email]
Gearhead210
01-18-2014 10:34:15
50.33.225.217
Fixing the one hole would be ok, as long as you pulled all the other pistons out and at least re-ringed them, and flex honed the cylinders. A customer at our shop found this out the hard way. My reason for saying this, is that the one new piston and rings would be sealing much better than all the others, therefore trying to do much more work than all the others.
My suggestion: Replace the bad piston/sleeve, and re-ring the others and flex hone the other cylinders to de-glaze the bores. While pistons and rods are out, and the pan is off, check out the oil pump and re-bearing the rod brgs. Since the heads will already be off, at least lap the valves in on all cylinders, or have them ground so that they are all sealing equally cylinder to cylinder.
My bets are that it has a cracked ring or stuck ring, and the fire is burnt behind the rings- from what you are explaining and what I have seen in the past. If you like the tractor and want it to be around a long time, don't leave the other cylinders alone or you'll be pulling it back apart in one season. It happened on a 2745 that a guy wanted to "save some money" on, and it was right back in the shop after fall plowing one season. This time it got the major overhaul that we suggested in the first place. It's not fun doing stuff twice :)
Hope this helps,
Richard
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
