Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
MH 30 gearing?
Zack b
01-13-2014 17:07:16
71.164.78.79
I have a Massey Harris 30 has 13.6x38 tires on it. Only thing I use it for is antique tractor pulls. It is geared too fast for stoneboat. Will stall out within 20 feet. Motor runs good. Have head off and all looks good inside. Was hoping someone would know of a ring and pinion with a lower ratio I could swap in. I heard a cockshutt transmission is similar. Any input would be great. Worst comes to worse I am gonna cut my centers out and put them in a set of 14.9x28 I have available
[Reply]   [No Email]
Zack b
01-15-2014 14:11:39
71.164.78.79
 Re: MH 30 gearing? in reply to Zack b, 01-13-2014 17:07:16
Ok. Think I'll go smaller tires. Thanks for the help
[Reply]  [No Email]
Zack b
01-14-2014 14:54:22
71.164.78.79
What are the differences in ratios between the transmission inputs? And is there any way other than counting teeth to tell what I have and what a different transmission has? Thanks
[Reply]  [No Email]
Mike in Mn.
01-14-2014 21:09:03
184.12.40.11
 Re: MH 30 gearing? in reply to Zack b, 01-14-2014 14:54:22
Counting teeth would give you an answer for sure. I don't know this for sure but I have always been told that the 30 and 44-6 Masseys were geared a little lower than the 33 and 44's because the flathead engines ran so much faster, same ring and pinion but slower in low gear, if that is true then you already have the slow gear in your 30. You would have to get into a parts book, I don't have one.
[Reply]  [No Email]
MH55
01-15-2014 07:56:59
24.39.238.234
 Re: MH 30 gearing? in reply to Mike in Mn., 01-14-2014 21:09:03
1st, 4th, and 5th are the same across all 30's, 33's and 44's
2nd, and 3rd were slower in 30's and 44-6's to compensate for faster engine speed...
Smaller tire or custom gears is about the only way to slow that 30 down.
[Reply]  [No Email]
Mike in Mn.
01-13-2014 22:54:54
74.46.182.161
That's a big tire for a 30, they came with 11.2 and 12.4 from the factory. I have 3 of them that I still use, one with 11.2, one with 12.4 and one with 13.6, the tire size makes a huge difference. The one with 13.6 is pretty tame. I'm dropping a tire size on my 44 puller for next summer, from 13.6 down to 12.4, I get beat by guys runnin 12.4's fairly often. On a super good biting clay track I can kill it in 2nd with the 13.6's. Where the speed limit is 3mph I run 14.9's and 1st gear and pull heavier.
[Reply]  [No Email]
Dieseltech
01-13-2014 18:37:33
199.16.223.2
MH never had ring and pinion gear tooth count changes between standard and row crop tractors in the parts books I have. Transmission inputs had changes depending whether 1350 or 1500 rated speed under load. The F162 engine is a good runner, but was always short on power compared to other engines. Cockshutt parts will not fit the MH rear end as they are completely different.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
