Eldon (WA)
Took the starter off, last fall it appeared the solenoid was stuck as starter kept running even with the key off. Had to disconnect the battery or everything would have gone up in flames. Anyway, I pulled the solenoid off and took the two Phillips screws off the back thinking the cap with the electrical studs would come off. It wiggles but seems to be stuck....and I don't want to force it off. Could the contacts be welded together and keep it from coming off? I checked continuity and none between the two big studs, but continuity between the spade connector and stud that goes to the stator...that doesn't seem right. Any tips??
