perkins AD4 203 injectors
rust-o
I am in the process or rebuilding the engine on my Massey 165 and I'm wondering what should be done with the injectors.
Should I take them to the local diesel injection shop and get them to test the pattern, or replace tips or what? If so it this expensive?
Or just clean em up and pop em back in...probably not...
Thanks in advance
I'd definitely at the very least get them checked
at a diesel shop. They'll test for pressure and
spray pattern. A good tuned set of injectors makes
a heckuva difference in the way your engine will
start and run.
Get em checked. A local shop here charges $10/
injector or nothing if they are bad and get new ones
through them. Good piece of mind on a new engine.
(quoted from post at 16:18:25 01/11/14) Get em checked. A local shop here charges $10/
alright thats what I figured.
Just wanted a second opinion
Thanks
