TO 20 Head and manifold problems
Anonymous-0
Hello,
I am new to the forum. I have a TO 20 Fuguson replaced head gasket and now it wont fire up, checked carb., wiring getting fire, but wont start. First time to start after new gasket it started but was very hesitant, then after that no go. Any suggestios?? thanks,
Dave in NC
I'm thinking antifreeze leak on pistons Did you torque head bolts from middle out? Look at the plugs are they wet? Torque the head down again take plugs out blow air in there and dry it out some.
Have you done any diagnostics?
Are you getting fuel to the carb? Make sure the tank valve is open and remove the plug on the fuel bowl. Fuel should gush out like a cow peein' on a flat rock! If it dribbles or is intermittent find out why.
Did you replace the manifold gasket? Could have a leak there. Did you check the valve lash?
Do you have a FAT, BLUISH-WHITE SPARK THE COLOR OF LIGHTNING? If you don't, find out why.
