I have followed advice given on this forum in relation to a hydraulic issue posted on the 28.09.13. I removed the draft control spring assembly& replaced the plunger, rocker yoke, bushes & rubber boot on my MF 135
Once re installed the hydraulics appear to lift the slasher and operate as designed.
Alas my PTO is not working, I did remove the PTO plate & lever to access the filter initially , I thought I had re-installed correctly but it appears not.
Can you offer some advice on this subject ??
