Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
FE35 air in injector pump
OzMF35
12-25-2013 20:34:28
101.172.127.251
My FE/MF35 (not sure which it is!) with 23C has a problem at the moment in that I'm constantly getting air in the injector pump, which will cause the tractor to stall.
At first I thought it was just due to bouncing over some rough ground, shaking up the fuel and sucking through some air. But now its happening very often on flat ground with a full tank of fuel. It appears most when I'm working the tractor - not so much at low rpm/load. I suspect because the auto air bleed off system can't bleed it off quick enough? At the moment I'm trying to mow 5 acres with a 4 disc mower, its cutting out and I'm having to bleed the pump about every 2nd lap around the paddock.
There is no sign of air in the rest of the fuel system, cracking the top bleed screw on the pump, then bleeding the injectors gets it going every time. I cant see any fuel leaks, although the small cyindrical shaped device attached to the bottom of the pump does appear a bit weepy and the cork gasket between this and the pump is a bit swollen.
Where is this air getting in? Could it be a dodgy pump gasket somewhere like the one I mentioned?
[Reply]   [No Email]
OzMF35
12-27-2013 03:09:20
101.172.42.140
 Re: FE35 air in injector pump in reply to OzMF35, 12-25-2013 20:34:28
Yep, it was the lift pump. Did the 2hr dash to my tractor parts guy and picked up a new one, noticed the difference when priming immediately. Finished cutting my hay paddock and it didn't miss a beat!
[Reply]  [No Email]
samn40
12-27-2013 06:36:17
81.152.49.123
 Re: FE35 air in injector pump in reply to OzMF35, 12-27-2013 03:09:20
Thank goodness you have got it fixed....It is always nice to know that we helped! Sam
[Reply]  [No Email]
OzMF35
12-26-2013 19:04:16
101.173.127.226
Ok, I've dismantled and cleaned the low pressure side of the fuel system. I haven't replaced the fuel filters yet as I'm not near anywhere at the moment that I can get them. But was told they were new when I purchased the tractor and its only done 80hrs since then, so I cant see they'd be the problem.
The fuel tap/bowl did not have a screen on it - I was hoping this being clogged would have been the problem but no joy. There was a bit of crap in the fitting which screws into the tank but not enough to cause a problem. I dismantled the lift pump as well. I put it all back together and made sure everything was tight. If i remove the pipe that feeds the injector pump, I can pump the lift pump and get a small stream of fuel coming out so there didnt appear to be any major restriction.
I took it back out to the field with the mower and got about 30m before it started losing power and stalled again - bled the pump and got about another 20-30m and same thing. If anything its worse than before!
My lift pump has always been a bit weak I thought - whenever I've had to hand prime it just didnt seem to move a lot of fuel with each pump and I can never get a good spurt from the bleed screws - just a dribble, could this be a problem? It certainly sounds like a fuel starvation problem, I can drive it all day long at lower revs/load, it just seems to be at load ~1300-1500rpm that it dies.
[Reply]  [No Email]
samn40
12-27-2013 02:32:16
81.152.49.123
 Re: FE35 air in injector pump in reply to OzMF35, 12-26-2013 19:04:16
Ok, it does sound like you have a fuel lift pump problem. possibly either dirt in some of the valves or just a weak or busted diaphram. On pumping the lift pump you should be sending fuel from the bleed screws out at least 2-3 foot from the tractor. Try a new lift pump they are not very expensive....I sell them for about 17sterling.....does not take much downtime to cover that expense! Sam
[Reply]  [No Email]
samn40
12-26-2013 13:29:09
81.152.49.123
Also check the gauze filter inside the tank, on top of the drain tap. partial blockage of this can let the tractor run but then when you need to get some work done it will stop/starve of diesel. By the time you get to bleeding it, enough diesel has made it through the gauze to allow the tractor to start again. Another possible problem is the fuel lift pump. It could have a ruptured diaphram, allowing some engine fumes to mix with the diesel, giving the same effect as an air bubble. Let us know what yoy find please......Sam
[Reply]  [No Email]
Dieseltech
12-26-2013 04:38:29
98.206.80.148
Make sure all the filters are sealed correctly, no twisted O rings. Also check the constant bleed oriface fitting on top of the filter base. The small hole must be open. If plugged any air in top of base can't escape, and then gets to the injection pump causing shutdown. Hole is small, maybe .020 or .030 Inch size. If I remember correctly it is in the banjo bolt on top of the final filter. When it gets plugged it can drive you nuts, as engine will run awhile until it gets a gulp of air again. Happens on Perkins engines too, Just in case Tony is reading this!!!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
