Re: MF 50 Clutch adjustment
samn40
Are you talking Multi-power or just the high range on the main
gearbox? If it is multi-power then either you have dirty filters or
your pump is on it's way out!. With the amount of free play on your
clutch pedal it seems like you either have oil on the plate or just a
knackered clutch.
Sam
If you have free play in the pedal and the throw out bearing is not riding on the release levers,your clutch is worn out,just that simple,no sugar coating it.
