Hello all... Massey 65 question
nodollas
Hey guys, I'm a new member from S.C.... '63 diesel powered model 65 from a friend of mine. I was able to find the year by tractor serial number but cant find the correct SN for the engine.
Can someone tell me the right place to look? I'm just trying to get the correct info for parts and such.
Thanks
Welcome to the forum. There's a lot of good people on here who offer up some good advice. If I'm not mistaken the serial number will be on the left side, under the injector pump, and above the power steering pump. The 65 Massey has got to be my favorite.
Okay, I might of been mistaken, look at the same side, top right hand corner of the engine block. There's a stamped number there, right behind the throttle linkage.
OK I found it thanks! it's 2949744... does this tell me if it's the 203? Sorry for the hand holding.
Thanks again
It's for sure an 203. If the injectors are at an angle that means it's a direct injection. AD203 I believe they are called. No problem trying to help you out. It's 15 below here in NNY, so not leaving the house. Mine is serial number 2934667 but I thought mine was a 1965. I don't have a serial tag on mine. There's some pictures of mine posted a few pages back.
