MF 135 power steering filter
lstra
I want to change the p/s filter on my 135. It is a 3 cyl Perkins,1974 or 75 year model. Will the cover slide off after removing screws(enough room) or does pump need to be removed? Thanks for any info.
You should have room but if it is like mine was there is a spring that holds the filter in place and it will be difficult to put it back together in the vertical position.
It's very easy to remove the pump.
I remove it in order to replace the filter and properly clean the reservoir and pump.
Dean
