TractorLinks.com
Show Parts for Model:
Re: massey fergusson 35
Maxwell 99
12-07-2013 04:22:11
On my to-35 if you pull the choke rod and close off inlet air to the carb,
the motor slows and the engine will die if choke is not released.
I would assume your carb is stopped up an needs a good soaking in carb cleaner and a rebuild.
After motor warm-up, my tractor will idle at 400 rpm's. Also, the motor should take the fuel without hesitation under load.
You may need a full tuneup, I normally get tuneup parts at napa including new spark plug wires.
Your air filter tower may be stopped up with dirt, that will require it be taken off, soaked in cleaner and washed out.
brian stanek
12-07-2013 11:42:41
 Re: massey fergusson 35 in reply to Maxwell 99, 12-07-2013 04:22:11
thanks for the info i ordered a carb kit i cleaned the air cleaner but will take a second look.
Maxwell 99
12-07-2013 23:39:19
 Re: massey fergusson 35 in reply to brian stanek, 12-07-2013 11:42:41
I took the air cleaner tower off the tractor and soaked it in a 5 gallon bucket of kerosene.
Rinsed it out over and over until the kerosene ran clean. Let it drip and air dry for about 8 hrs.
Fresh oil in the air filter cup and you should be good to go.
I would not try to take the wire mesh material out of the air filter tower to clean it, just soak it.
