Massey Harris 30
I'm located in SW Indiana. I guess if the price was right id consider a running one. I like to work on these tractors so I usally look for the non runners because there cheaper.
It does need the brakes worked on as the diff shaft seals need replaced as they are leaking. Has been changed to 12 volt system, with generator. Rear tires are original 11-38, still about 80% tread. Was told it only pulled a hay rake. If you like call 574 893 4172, after 7 PM is best.
Hi Smokeshow, I have a 1951 Massey Harris 30. Good tin, new rubber all around. Has hydraulics. Runs but has a miss in one cylinder. Uses a little oil and smokes some. I found a pair of fenders for it. I have a guy doing some "rust rot" repair on them.
I would consider selling it as is.
